The Woodpeckers StealthStop Mitre Gauge brings precision and repeatability to crosscutting and angled cuts on your table saw. Its self-adjusting leaf-spring mitre bar provides a smooth, secure fit in compatible mitre slots, while positive angle stops make it quick and easy to set commonly used cutting angles.
Designed for accurate and versatile setup, the gauge features positive stops at 0°, 15°, 22.5°, 30°, 36°, 45° and 60° in both directions. Simply depress the button as you approach the required angle to engage the stop. For other angles, a large laser-engraved protractor provides a clear reference for precise adjustment. The included extendable fence provides 521mm (20-1/2) of continuous support, extending to 737mm (29) for larger workpieces.
The patented leaf-spring mitre bar automatically expands and contracts to accommodate compatible slots from 18.8 to 19.4mm (0.742 to 0.765) wide, helping eliminate unwanted side-to-side movement. Two removable T-track retainers provide additional support in T-slot mitre tracks. The adjustable StealthStop can be positioned anywhere along the fence for repeat cuts, with a built-in micro-adjuster for fine adjustment. When not required, the stop swings sideways completely out of the way.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Its products are precisely machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers looking for accurate crosscuts, mitres and repeat cuts, the Woodpeckers StealthStop Mitre Gauge combines precise angle adjustment with excellent workpiece support.
The extendable fence and micro-adjustable StealthStop make it particularly useful when producing multiple components to a consistent length. Supplied with: StealthStop Mitre Gauge with extendable fence, two StealthStops flipstops, fence blocks with fixings and screwdriver.
Web Attribute Set Saw Bench Accessories
