{"product_id":"woodpeckers-stealthstop-mitre-gauge","title":"Woodpeckers Stealthstop Mitre Gauge","description":"\u003cp\u003eThe Woodpeckers StealthStop Mitre Gauge brings precision and repeatability to crosscutting and angled cuts on your table saw. Its self-adjusting leaf-spring mitre bar provides a smooth, secure fit in compatible mitre slots, while positive angle stops make it quick and easy to set commonly used cutting angles.\u003c\/p\u003e\u003cp\u003eDesigned for accurate and versatile setup, the gauge features positive stops at 0°, 15°, 22.5°, 30°, 36°, 45° and 60° in both directions. Simply depress the button as you approach the required angle to engage the stop. For other angles, a large laser-engraved protractor provides a clear reference for precise adjustment. The included extendable fence provides 521mm (20-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) of continuous support, extending to 737mm (29\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) for larger workpieces.\u003c\/p\u003e\u003cp\u003eThe patented leaf-spring mitre bar automatically expands and contracts to accommodate compatible slots from 18.8 to 19.4mm (0.742\u003cspecial id=\"32\"\u003e\u003c\/special\u003e to 0.765\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide, helping eliminate unwanted side-to-side movement. Two removable T-track retainers provide additional support in T-slot mitre tracks. The adjustable StealthStop can be positioned anywhere along the fence for repeat cuts, with a built-in micro-adjuster for fine adjustment. When not required, the stop swings sideways completely out of the way.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Its products are precisely machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers looking for accurate crosscuts, mitres and repeat cuts, the Woodpeckers StealthStop Mitre Gauge combines precise angle adjustment with excellent workpiece support.\u003c\/p\u003e\u003cp\u003eThe extendable fence and micro-adjustable StealthStop make it particularly useful when producing multiple components to a consistent length. Supplied with: StealthStop Mitre Gauge with extendable fence, two StealthStops flipstops, fence blocks with fixings and screwdriver.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036571517275,"sku":"114898","price":139.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114898_xl.jpg?v=1793618675","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-stealthstop-mitre-gauge","provider":"Axminster Tools","version":"1.0","type":"link"}
