The Woodpeckers Super Track Flip Stop provides a quick and accurate way to set repeatable cutting or routing positions when used with Woodpeckers Super Track or SuperFence systems. Designed for stop-and-repeat operations, the flip arm can be positioned in the work path for consistent results and then flipped out of the way when clearance is required.
The robust aluminium construction provides a stable reference point for repetitive work, while the flip arm can be mounted in two positions to suit use with or without a sacrificial fence. The design also allows the flip arm to be mounted on either side of the main body for added flexibility.
The stop mounts into the upper track of compatible Woodpeckers Super Track and SuperFence systems using a 1/4-20 hex-head bolt. The flip arm measures approximately 114.3mm (4-1/2) on its outer face and 98.2mm (3.865) on its inner face, providing a substantial contact surface for accurate positioning.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for router tables, mitre saw stations, chop saw fences and custom jig applications, the Woodpeckers Super Track Flip Stop provides fast, repeatable positioning for production work and repetitive cuts. Supplied: One Woodpeckers Super Track Flip Stop.
Overall L x W x H L 114.3mm x W 38.1mm x H 15.9mm
Web Attribute Set General Machine Accessories
EAN Barcode 0091037316288
