The Woodpeckers Taper Sled is a versatile table saw accessory designed for cutting accurate tapers, straight-lining rough-sawn timber and supporting a wide range of angled cutting operations. Built around a rigid sled platform, it combines flexible work holding, an adjustable fence system and a self-adjusting mitre bar to provide reliable, repeatable results.
The patented mitre bar features nylon leaf springs that automatically compensate for variation and wear in standard 19.1mm x 9.5mm (3/4
An adjustable hook stop provides up to 19.1mm (3/4
The taper-setting scales are positioned 609.6mm (24
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers producing tapered legs, straight-lined boards and custom angled workpieces, the Woodpeckers Taper Sled provides accurate guidance, flexible workholding and repeatable setup. Supplied with: Woodpeckers Taper Sled 32
