{"product_id":"woodpeckers-taper-sled-32","title":"Woodpeckers Taper Sled 32\"","description":"\u003cp\u003eThe Woodpeckers Taper Sled is a versatile table saw accessory designed for cutting accurate tapers, straight-lining rough-sawn timber and supporting a wide range of angled cutting operations. Built around a rigid sled platform, it combines flexible work holding, an adjustable fence system and a self-adjusting mitre bar to provide reliable, repeatable results.\u003c\/p\u003e\u003cp\u003eThe patented mitre bar features nylon leaf springs that automatically compensate for variation and wear in standard 19.1mm x 9.5mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) mitre slots, helping the sled run smoothly and accurately. For larger workpieces, the sled can be detached from the mitre bar and guided directly by the table saw fence, making it suitable for oversized tapering and straight-line ripping operations.\u003c\/p\u003e\u003cp\u003eAn adjustable hook stop provides up to 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) of support and can be retracted when not required. Additional clamp slots allow sacrificial stops and workholding accessories to be positioned along the length of the sled. Four track-clamp slots also make it easy to secure irregular or rough-sawn stock when the fence is not being used.\u003c\/p\u003e\u003cp\u003eThe taper-setting scales are positioned 609.6mm (24\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) apart, allowing rise-over-run measurements to be set quickly and accurately when creating tapered legs and similar projects. A wall-mounted Rack-It is included for convenient workshop storage.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers producing tapered legs, straight-lined boards and custom angled workpieces, the Woodpeckers Taper Sled provides accurate guidance, flexible workholding and repeatable setup. Supplied with: Woodpeckers Taper Sled 32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e and wall-mountable Rack-It.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036572500315,"sku":"114872","price":269.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114872_xl.jpg?v=1793618643","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-taper-sled-32","provider":"Axminster Tools","version":"1.0","type":"link"}
