{"product_id":"woodpeckers-versa-fence-face-upgrade-for-sawstop","title":"Woodpeckers Versa-Fence-Face Upgrade For Sawstop","description":"\u003cp\u003eThe Woodpeckers Versa-Fence Face Upgrade for SawStop transforms the T-Glide rip fence on compatible SawStop table saws, providing a straighter, longer and smoother reference surface with increased support for your workpiece. This 1,219mm (48\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) version is designed for the SawStop PCS T-Glide fence and installs without drilling or permanently modifying the existing fence.\u003c\/p\u003e\u003cp\u003eThe 22.2mm (7\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick fence features a hardcoat-anodised aluminium surface with PTFE to help material slide smoothly with minimal resistance. Tool-free knobs secure the Versa-Fence to the T-Glide fence, while its position can be easily adjusted to provide more support on either the infeed or outfeed side. It can also be swapped to the opposite side of the T-Glide when the rip fence is required to the left of the saw blade.\u003c\/p\u003e\u003cp\u003eAt 1,219mm (48\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) long, the Versa-Fence provides an extended reference surface for larger workpieces. The 178mm (7\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) material support can be positioned on either the infeed or outfeed side to provide additional support where needed. An integrated top track allows compatible JessEm Clear-Cut Stock Guides to be mounted without drilling the SawStop fence. Optional brackets can also be used with compatible Woodpeckers Variable Pressure Featherboards.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy, versatility and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for SawStop PCS owners looking to increase the support and versatility of their existing T-Glide fence, the Woodpeckers Versa-Fence offers a quick, non-permanent upgrade without the need for drilling or modification. Compatible with JessEm Clear-Cut Stock Guides, sold separately. Supplied with: Woodpeckers Versa-Fence Face Upgrade, 178mm (7\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) material support, mounting bracket and clamping knobs.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55174491111771,"sku":"114897","price":315.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114897_xl.jpg?v=1793618676","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-versa-fence-face-upgrade-for-sawstop","provider":"Axminster Tools","version":"1.0","type":"link"}
