{"product_id":"woodpeckers-wheel-marking-gauge-with-microadjust","title":"Woodpeckers Wheel Marking Gauge With Microadjust","description":"\u003cp\u003eThe Woodpeckers Wheel Marking Gauge with Micro-Adjust delivers crisp, precise layout lines for accurate hand-tool joinery. Its ultra-thin circular cutting wheel slices cleanly through the wood fibres rather than simply scratching the surface, creating a fine line that also provides a positive reference for positioning a chisel or saw.\u003c\/p\u003e\u003cp\u003eA large reference plate provides stable registration against the edge of the workpiece and can be fitted in two positions. Use the standard position for maximum edge support or rotate the plate through 90° for greater vertical support when marking narrow stock. The circular cutter also allows marking lines to continue cleanly around the edge of a workpiece.\u003c\/p\u003e\u003cp\u003eFine adjustment is controlled by a knurled micro-adjustment barrel, moving the cutting wheel 1.6mm (1\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) per full revolution for precise control of the marking position. The ergonomic anodised aluminium body features machined recesses for a secure grip, while the reference plate, adjustment components and circular cutter are designed for accurate, repeatable layout work.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers, joiners and hand-tool woodworkers laying out mortises, tenons and other precision joinery, the Woodpeckers Wheel Marking Gauge combines a fine cutting action with accurate micro-adjustment. Supplied: One Woodpeckers Wheel Marking Gauge with Micro-Adjust.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036590489947,"sku":"114858","price":119.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114858_xl.jpg?v=1793618596","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-wheel-marking-gauge-with-microadjust","provider":"Axminster Tools","version":"1.0","type":"link"}
