The Woodpeckers Woodworking Rule Bundle - Metric provides four precision measuring rules for accurate layout and marking across a wide range of woodworking projects. With 300mm, 600mm, 900mm and 1,200mm lengths, the set covers everything from smaller components to large panels, furniture and cabinet work.
Each rule features a standard left-to-right metric scale along one edge and a centring scale along the other. With zero positioned at the centre, the centring scale makes it quick and easy to find the midpoint of a workpiece or lay out equally spaced positions either side of centre, ideal for tasks such as positioning handles and hardware.
Machined from aluminium, the rules have 30° bevelled edges that bring the laser-engraved graduations close to the workpiece for clear, accurate marking. Finger grooves provide a secure grip, while a relieved section on the underside helps the measuring edges sit flat against your work. The laser-engraved scales have a stated tolerance of ±0.1mm (±0.004
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers who want precision metric rules for both general measuring and centre-finding tasks, this bundle provides four useful lengths for a wide variety of projects. The rules are also compatible with the optional Woodpeckers Hook Stop and Rule Stop. Supplied with: Woodpeckers Woodworking Rules in 300mm, 600mm, 900mm and 1,200mm lengths.
