The Woodpeckers Woodworking Rule Protractor Head converts a compatible Woodpeckers Woodworking Rule into a precision adjustable T-square, enabling accurate angle layout from 0° to 180°. Designed to mount directly to Woodpeckers Woodworking Rules using the same threaded holes as the Hook Stop, it adds versatility without sacrificing the accuracy and ease of use for which the rules are known.
The precision-machined head pivots smoothly with minimal backlash, allowing angles to be set accurately and locked securely in position using twin locking knobs. A crisp laser-engraved scale and calibrated indicator make angle setting straightforward, while the large reference face provides confident registration during marking and layout tasks.
Machined from aluminium and finished with a durable anodised coating, the Protractor Head is designed for long-term workshop use. The angle indicator can be recalibrated if required, ensuring continued accuracy over time. Compatible with all Woodpeckers Woodworking Rules except the 152.4mm (6) version, it provides an effective solution for laying out angled lines, checking existing angles and creating precise setup references.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers requiring accurate angle transfer and layout work, the Woodworking Rule Protractor Head expands the capabilities of existing Woodpeckers Woodworking Rules. Supplied with: Woodpeckers Woodworking Rule Protractor Head and wall-mountable Rack-It.
Web Attribute Set Protractors
EAN Barcode 0810018208172
