{"product_id":"yorkshire-grit-microfine","title":"Yorkshire Grit Microfine","description":"\u003cp\u003eYorkshire Grit is an abrasive paste used by woodturners across the world. Available in both Microfine (for resins\/hybrids\/wood) and Original (for wood), it’s known for its effectiveness in enhancing the surface of wood and achieving a smooth, polished finish.\u003c\/p\u003e\u003cp\u003eYorkshire Grit Microfine is an advanced abrasive paste designed for woodturners to achieve an exceptionally smooth and fine surface finish on wooden surfaces. The abrasive paste gives a fine keyed surface to your woodturning projects before adding a final finish. The products contain an ultra-fine, hand-blended mix of mineral oil, beeswax and abrasive powders that are carefully processed together without the use of solvents or other strong smelling and potentially harmful chemicals. The result is a creamy paste that acts like “liquid sandpaper” which reduces scratches left behind by lower grit dry sanding, and eliminating fine dust produced by higher grit sanding.\u003c\/p\u003e\u003cp\u003eMade in the U.S.A\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118499909979,"sku":"109977","price":19.78,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109977_xl.jpg?v=1789782932","url":"https:\/\/www.axminstertools.com\/products\/yorkshire-grit-microfine","provider":"Axminster Tools","version":"1.0","type":"link"}
