This replacement blade secures to the wrapped handle by a simple screw. One edge has teeth for ripping, with smaller teeth near the handle to use when starting the cut, before bringing the full effective edge to bear on the workpiece. The other edge has crosscut teeth which produce a wonderfully clean cut surface. Length 250mm.
Blade Thickness 0.50 mm
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511094455
