This specially designed dozuki saw blade easily clips into the handle of our Dozuki-Me Saw. It has sturdy teeth and a fine 21tpi pitch. These robust and sharp teeth are perfect for cutting precise joints in hardwoods. The special tooth grind enables cross, rip and mitre cuts with equal precision.
Blade Thickness 0.30 mm
Tooth Pitch \ tpi 1.21 mm \ 21 tpi
Length of Blade 240 mm
Saw Blade Type Crosscut
Web Attribute Set Japanese Back Saws
EAN Barcode 4963041071247
