Tools from Japan
Z-Saw Blade for Japanese Fixed Pruning Saw in Sheath - 270mm
SKU: 103689
£5.68
£4.73 Excl. VAT
  • Easily changed, replacement blade
  • Clean cutting, impulse hardened teeth, 270mm long
  • Universal ground teeth for fast cutting action
  • High quality Japanese steel, Ni-P plated
This replacement blade secures to the handle by a simple screw. The diamond ground teeth cut on both the pull and push stroke, producing fast and clean results. The blade has impulse hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The 270mm long blade is replaceable; it is 0.70mm thick with a 2.4mm pitch.
Blade Thickness 0.70 mm
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511094370
