This replacement blade secures to the handle by a simple screw. The diamond ground teeth cut on both the pull and push stroke, producing fast and clean results. The blade has impulse hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The blade is 210mm long and 0.9mm thick with a 1.18mm kerf and a 3.0mm pitch.
Blade Thickness 0.90 mm
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511094332
