This replacement blade secures to the handle by a simple screw. The diamond ground teeth cut on both the pull and push stroke, producing fast and clean results. The blade has impulse hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The blade is 240mm long, 1.0mm thick with a 1.28mm kerf and a 3.2mm pitch.
Blade Thickness 1.00 mm
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511094356
