The 265 Kataba is the Z Saw Company’s top-notch general-purpose saw. Site saw sounds a little derogatory, but in essence, this saw performs a similar function albeit in the splendid Japanese fashion. It will cut solid wood, plywood, laminate, man-made sheet, plastics etc. It gives a fast cut, excellent for crosscutting larger section timber. The 265 features a rattan wrapped solid wood handle. The easy change blade fitting gives the benefits of rapid replacement of spare or alternative blades and with the blade removed, the saw fits into most toolboxes. Impulse hardened, diamond ground, sharp teeth give you long-lasting performance. 265mm long blade. Overall length 595mm.
Tools from Japan
Z-Saw Japanese 265 Kataba Crosscut Saw - 265mm
| Blade Thickness | 0.60 mm |
| Web Attribute Set | Japanese Kataba Saws |
| EAN Barcode | 4963041150034 |
