{"product_id":"z-saw-japanese-compact-kataba-saw-200mm","title":"Z-Saw Japanese Compact Kataba Saw - 200mm","description":"\u003cp\u003eThis compact saw with a 200mm long blade is ideal for use in confined spaces or tight spots where conventional saws are too large. The sharply ground universal teeth (rip\/cross\/mitre cut) can easily cope with cutting solid wood, plywood, blockboard etc.\u003c\/p\u003e\u003cp\u003eImpulse hardening means the teeth stay sharp much longer for long-lasting great performance. The thin kerf and pull-stroke action make cutting almost effortless. Changing blades is a simple tap to loosen the old blade and then clipping a new one in place. This is also an advantage by allowing you to separate the blade from the handle for safer and easier storage in a toolbox. The ergonomic handle flares slightly and has a rubber coating for a comfortable and secure grip. Overall, it makes a jolly handy small saw.\u003c\/p\u003e\u003cp\u003eBlade length: 200mm, thickness: 0.50mm, kerf: 0.70mm, pitch: 1.75mm.\u003c\/p\u003e","brand":"Zet Saw","offers":[{"title":"Default Title","offer_id":54118242648411,"sku":"103694","price":15.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103694_xl.jpg?v=1789773121","url":"https:\/\/www.axminstertools.com\/products\/z-saw-japanese-compact-kataba-saw-200mm","provider":"Axminster Tools","version":"1.0","type":"link"}
