Zet Saw
Z-Saw Japanese Hassunme Crosscut Saw - 250mm
SKU: 110039
€21,00
  • Tooth form leaves incredible finish on end grain
  • Replaceable 0.5mm thick and 250mm long blade
The tooth form of this crosscut saw leaves the most incredible finish on end grain, almost like a planed surface. Featuring a replaceable blade 0.5mm thick and 250mm long, this saw will produce cuts to be proud of. N.B. The blades are interchangeable between Hassunme saws.
Blade Length 250mm
Web Attribute Set Japanese Kataba Saws
EAN Barcode 4963041150065
