The tooth form of this crosscut saw leaves the most incredible finish on end grain, almost like a planed surface. Featuring a replaceable blade 0.5mm thick and 250mm long, this saw will produce cuts to be proud of. N.B. The blades are interchangeable between Hassunme saws.
These blades are 0.5mm thick blade, 250mm long for effortless ripping of long boards. Changing a Hassunme blade couldn't be easier; gently tap the back of blade on a block of wood until it comes loose. Remove the old blade, insert the new one into the holder and tap the back of the holder on the block to seat the blade.
