This package deal represents great value and comprises the Japanese Hassunme Crosscut Saw and a spare blade.
The tooth form of this crosscut saw leaves the most incredible finish on end grain, almost like a planed surface. Featuring a replaceable blade 0.5mm thick and 250mm long, this saw will produce cuts to be proud of.
Japanese Hassunme Crosscut Saw Replacement Blade
Changing a Hassunme blade couldnt be easier; gently tap the back of blade on a block of wood until it comes loose. Remove the old blade, insert the new one into the holder and tap the back of the holder on the block to seat the blade. These blades are 0.5mm thick blade, 250mm long for effortless ripping of long boards or crosscutting, leaving a smooth finish on end grain.
Web Attribute Set Japanese Kataba Saws
EAN Barcode 5052511075461
