{"product_id":"z-saw-japanese-heavy-duty-carpenters-saw-333mm","title":"Z-Saw Japanese Heavy-Duty Carpenter's Saw - 333mm","description":"\u003cp\u003eThis professional grade Japanese saw features a long, sturdy saw blade, suited to timber framing and other large-scale carpentry projects. The universal teeth pattern allows for fast crosscut, mitre-cut and rip-cut performance in soft and hard woods, both seasoned and green. The high quality carbon steel blade is hardened (53-54 HRC), giving the blade flexibility and durability. The Japanese Tri-Edge-Teeth design provides for a highly efficient cutting performance, leaving a very clean and smooth cutting surface. The tips of the teeth undergo additional impulse hardening process to 68-70 HRC. This leaves the core and the base of the teeth tough and flexible. The result is a saw tooth that has a very long edge and resistance to breakage. Changing is a simple tap to loosen the old blade and then clipping a new one in place. This is also an advantage by allowing you to separate the blade from the handle for easy storage and transport in a toolbox. The handle has a soft grip for comfort offering better control. Overall length 720mm, blade length : 333mm, thickness : 0.8mm, kerf : 1.1mm, pitch : 2.8mm.\u003c\/p\u003e","brand":"Zet Saw","offers":[{"title":"Default Title","offer_id":54118238486875,"sku":"103690","price":21.28,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103690_xl.jpg?v=1789773096","url":"https:\/\/www.axminstertools.com\/products\/z-saw-japanese-heavy-duty-carpenters-saw-333mm","provider":"Axminster Tools","version":"1.0","type":"link"}
