This is a smaller version of the Dozuki has a 150mm long blade with 30mm depth of cut. The blade features a special pecker tooth at the tip allowing you to start a cut in the middle of a panel. With a blade thickness of a mere 0.3mm and the kerf 0.49mm, with its fine 18tpi it makes a handy saw for a range of fine, small sawing tasks and close joints. The blades are easy to replace. The handle has a comfortable, textured elastomer grip. The overall length is 370mm.
Tools from Japan
Z-Saw Japanese Small Dozuki Panel Saw - 150mm
| Blade Thickness | 0.30 mm |
| Web Attribute Set | Japanese Back Saws |
| EAN Barcode | 5052511130924 |
