Tools from Japan
Z-Saw Japanese Small Dozuki Panel Saw - 150mm
SKU: 109379
€15,00
  • Useful saw for a small sawing tasks and close joints
  • Thin kerf, fine blade with steel spine for support
  • Comfortable, textured elastomer grip
  • Pecker tooth for starting a cut in the middle of a panel
  • Cuts on pull stroke offering excellent control
This is a smaller version of the Dozuki has a 150mm long blade with 30mm depth of cut. The blade features a special pecker tooth at the tip allowing you to start a cut in the middle of a panel. With a blade thickness of a mere 0.3mm and the kerf 0.49mm, with its fine 18tpi it makes a handy saw for a range of fine, small sawing tasks and close joints. The blades are easy to replace. The handle has a comfortable, textured elastomer grip. The overall length is 370mm.
Blade Thickness 0.30 mm
Web Attribute Set Japanese Back Saws
EAN Barcode 5052511130924
