Proxxon 50mm Sanding & Polishing Pads
- Suitable for porcelain stoneware, ceramics, stoneware and more
- Ideal for edge removal, bevelling and chamfering
- Compatible with Angle polisher WP/A and WP/E
- Available in four grit sizes (50, 100, 200, 400)
PROXXON Battery Powered Angle Polisher WP/A (Body Only)From £119.98 £99.98
Achieve a flawless finish on a variety of materials with the PROXXON Diamond sanding and polishing pads. Perfect for porcelain stoneware, ceramics, natural stone, artificial stone, and brick, these versatile pads are compatible with Angle polisher WP/A and WP/E. Ideal for edge removal, bevelling, and chamfering, it excels in dry grinding and polishing applications.
Available in four grit sizes (50, 100, 200, 400), it ensures precision and efficiency for all your projects.
Grit size 50: This is the coarsest option, suitable for heavy material removal and initial grinding.
Grit size 100: This is slightly finer, used for intermediate grinding and smoothing out rough surfaces.
Grit size 200: This is a medium grit, ideal for further refining the surface and preparing it for final polishing.
Grit size 400: This is the finest option, perfect for achieving a smooth, polished finish.
