PROXXON 51 Piece Universal Tool Set in L-BOXX
- Covers a wide range of general mechanical and automotive tasks
- 51 first class industrial quality tools in a tough L-BOXX
- L-BOXXs are compatible with numerous in-vehicle or van racking systems
Customers Also Bought
The set comprises 51 industrial, professional quality tools with 5 stars for usefulness. The PROXXON Universal set contains a carefully chosen selection of PROXXON and other German made tools. The selection covers a wide range of general mechanical and automotive tasks. The sockets and accessories are all CrV steel (31 CrV 3) to DIN 899. Knipex makes both the 180mm combination pliers and 240mm water pump pliers. The kit includes a good selection of screwdrivers and hex keys. Finally, if all else fails, there is a 300g hammer with a fibreglass reinforced handle.
All this comes in an L-BOXX (102). Developed in partnership with Bosch and Sortimo; these extremely robust cases are easy to transport and store. L-BOXXs are compatible with numerous in-vehicle or van racking systems available in the market.
Overall length 442mm, width 357mm and depth 117mm.
- Comprises:
- 15 x SlimLine combination spanners 6 - 21mm
- 14 x sockets 1/2" (12.5mm) 8 - 24mm,
- 1 x standard ratchet 1/2",
- 2 x universal joint, extensions 125 and 250mm
- 4 x deep sockets 10 - 19mm
- 2 x MicroSpeeder ratchet spanners 10x13 and 17x19mm
- 5 x slot screwdrivers 3 - 6.5mm
- 2 x Phillips screwdrivers PH 1 and PH 2
- 1 x Voltage tester
- 2 x Hex key sets Hex and Torx (9-piece each)
- 1 x KNIPEX combination pliers 180mm
- 1 x KNIPEX water pump pliers 250mm
- 1 x Cross-pein hammer (300g) with graphite handle
