PROXXON AP 12 Universal Oil Pump 12V DC
474928
From £62.98 £52.48
  4. Half Star
3 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Wednesday 16th Jul
  • Perform an oil change in just 2-3 minutes
  • Pumps, motor, diesel and heating oil effortlessly
  • 250 litres an hour (fitted with a 1/2" feed hose)
  • Pumps the oil out of an engine via the dipstick shaft
  • Includes a 6mm diameter dip wand
  • Crocodile clips fitted suitable for connection to a car battery
  • 130 x 90 x 90mm, weight 1.4kg
  1. PROXXON AP 12 Universal Oil Pump 12V DC
Total:
£308.12 £256.77
This small neat unit is will help you perform an oil change in just 2-3 minutes.
This pump transfers, motor, diesel and heating oil effortlessly at a rate of 250 litres an hour (fitted with a 1/2" feed hose). You can pump the oil out of an engine via the dipstick shaft in which case the flow rate is 3 litres per minute at 40°C oil temperature. The unit includes a 6mm diameter by 800mm long dip wand for this purpose. The crocodile clips fitted to the 12 Volt DC feed cables are suitable for connection to a car’s battery. The feed and supply sides have 1/2" connectors. An outlet hose of approximately 1,500mm is also included. The housing is made of glass fibre reinforced polyamide; approx 130 x 90 x 90mm. Weight is approx 1.4kg.
3.70 3
