This small angle polisher uses a quiet, powerful DC motor powered by a 10.8V Li-ion battery. This cordless version offers freedom and flexibility for polishing, cleaning, rust removal and many other tasks.
It features continuously variable speed control (full-wave electronics) for constant speeds under load. Motor power is transferred to the planetary gearing, contained in robust die-cast aluminium housing. The main body of the machine is glass-fibre reinforced polyamide with a rubberised grip for comfort and greater control.
Supplied with a rubber backing disc with a hook and loop fastening, polishing sponge (medium hard), lambswool polishing disc, polishing felt for metals and non-ferrous metals (medium hard), 12 sanding discs 2,000 grit and NIGRIN polishing emulsion (75ml) as well as a microfibre cloth.
Please note, this is a body only tool supplied without battery or charger in a cardboard box.
For polishing, cleaning, sanding and light rust removal
Comparable performance to mains powered equivalent
Angle head, perfect for finishing, even in tight spots
Variable speed for wide variety of applications
Soft component grip for comfort and control
Supplied with a range of accessories
Body only tool supplied without battery or charger in cardboard box
Please enable "Performance Cookies" for our best Reviews and Q&A experience. To change your cookie preferences please see our Cookie Policy.
Do the Bosch 10.8v batteries work with the Proxxon polisher?
Asked by: Anonymous
Hello,
Bosch 10.8v batteries are not compatible with Proxxon products.
Sam
Specialist Sales Advisor
Answered by: Axminster Staff
Date published: 2019-04-16
Are the accessories included?
Asked by: rodger
Hello
This is supplied with a rubber backing disc with a hook and loop fastening, polishing sponge (medium hard), lambswool polishing disc, polishing felt for metals and non-ferrous metals (medium hard), 12 sanding discs 2,000 grit and NIGRIN polishing emulsion (75ml) as well as a microfibre cloth.
Kind regards
Tony Specialist Sales Advisor
Date published: 2019-09-05
I would like to use diamond grinding/sanding pads for small glass projects. Do you know if these are available for the Proxxon?
Asked by: Maxine
Hello
Regretfully Proxxon do not supply any diamond grinding/sanding discs for this machine, please find a link below to their website which shows the range of accessories available.
https://www.proxxon.com/en/micromot/29820.php?search#29822
Scott
