PROXXON IBS/A Cordless Drill/Grinder - (Body Only)
- For drilling, milling, grinding, polishing, cleaning, cutting and engraving
- Variable electronic speed control, high torque, even at low speed
- Collet tool holder for high concentric accuracy
- Die-cast aluminium head ensures long, trouble-free working life
- Comfort grip for greater control
- Body only supplied without battery and charger
Perfectly precise with PROXXON - The 20mm Collar System
The 20mm collar range of PROXXON tools allows you to easily connect to one another and achieve maximum precision and versatility with your intricate tasks. Simply clamp the collar of your PROXXON drill or grinder to the drill stand, universal holder or router base and your tool is held steady whilst allowing you to take on a range of tasks including routing, engraving and drilling.
The IBS/A is suitable for drilling, milling, grinding, polishing, cleaning, cutting, engraving and signing. It has a variable electronic speed control offering high torque, even in the lower speed range. It has a collet tool holder and comes with six triple slit MICROMOT steel collets (1, 1.5, 2, 2.4, 3 and 3.2mm) for high concentric accuracy. The 20mm MICROMOT collar allows use in drill and horizontal stands. This professional quality cordless MICROMOT tool combines the features of its mains equivalent with the convenience of a cordless tool. The main bearings and gears sit in a die-cast aluminium head ensuring a long, trouble-free working life. The glass fibre reinforced POLYAMIDE main body houses a special balanced, powerful, quiet and long-lasting DC motor. The soft component body grip offers comfort and greater control. This is a body only tool supplied without batteries and charger.
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 10.8 V |
Corded or Cordless | Cordless |
EAN Barcode | 4006274298026 |
Model | IBS/A |
Nett Weight | 0.7 kg |
Rating | Trade/Professional |
RPM | 7,000 - 23,000 rpm |
This product is classified as a Make to Order product.
Delivery time is approximately 3 weeks.
- Standard Delivery* - Free
