PROXXON Battery-Powered Long Neck Angle Grinder LHW/A
102370
From £175.98 £146.65
6 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 24th Jun
  • For steel, non-ferrous metals, glass, ceramics, wood and plastic
  • Quiet and long lasting DC motor
  • 10.8V (2.6Ah) lithium-ion battery for mains comparable performance
  • Die-cast aluminium head ensures long, trouble-free working life
  • Comfort grip for greater control
  • Supplied with grinding disc, fan sander and cutting disc in tough polypropylene case
  1. PROXXON Battery-Powered Long Neck Angle Grinder LHW/A
Total:
£188.42 £157.02
You can use the LHW/A for work on steel, non-ferrous metal, glass, ceramics, wood and plastic. It can cut, texture, sand or grind. The variable electronic speed control still has high torque, even in the lower speed range. It takes 50mm diameter discs. The extended neck allows easy access into narrower spaces. This professional quality battery-powered MICROMOT tool combines the features of its mains equivalent with the convenience of a cordless tool. The 10.8V, 2.6Ah lithium-ion battery gives a performance comparable to its mains-powered counterpart. The main bearings and gears sit in a die-cast aluminium head ensuring a long, trouble-free working life. The glass fibre reinforced POLYAMIDE main body houses a special balanced, powerful, quiet and long lasting DC motor. The soft component body grip offers comfort and greater control. The flat end cap on the battery enables the tool to stand upright when not in use. Overall length 320mm. Complete with a corundum-grinding disc (grit 60), a fan sander (grit 100) and a reinforced cutting disc, lithium-ion battery (10.8 V), fast charger and virtually unbreakable polypropylene case.
4.8 6
