Proxxon Diamond Coated Cutting Disc with Turbo Rim
- Cuts stone, marble, granite and ceramic
- Ideal for detailed tile treatment work
- Provides rapid and clean results with 1.7mm thickness
- Compatible with long neck angle grinder LHW & LHW/A
Proxxon Diamond Coated Fine Cutting DiscFrom £12.31 £10.26 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14
Upgrade your tile treatment toolkit with the PROXXON 50mm Diamond-Coated Cutting Disc featuring a Turbo Rim. Designed for the Long Neck Angle Grinder LHW & LHW/A, this disc ensures extremely fast (dry) cuts and exceptional durability in granite, marble, stoneware, and ceramic materials. Additionally, it allows cuts in other materials such as metal, porcelain stoneware, ceramics, natural stone, artificial stone, brick, gypsum, and plaster.
The Turbo Rim enables high dust removal on the cutting edge and outstanding durability. It re-sharpens itself during use in stoneware and is suitable for highly abrasive materials. Perfect for cutting corner protection profiles without tempering colours, this disc has a thickness of just 1.7mm, providing clean and precise results every time.
| D = Overall Diameter | 50 mm |
| EAN Barcode | 4006274281578 |
- Standard Delivery* - £5
