From £30.98 £25.82
Available to Backorder
- dispatch estimate is within 2 weeks. Delivery info
  • PROXXON 18mm Sanding Discs with Arbor
  • Self adhesive sanding discs
  • Mount on to a rubber faced arbor
Customers Also Bought
Total:
£223.42 £186.18
Package deal comprises accessory for use with the PROXXON drill/grinder.
18mm diameter self adhesive sanding discs which mount onto a rubber faced arbor. Arbor plus 5 x 120 grit and 5 x 150 grit discs. 3mm shaft diameter.
PROXXON Flap Sanding Wheel
For general shaping and smoothing work on various materials. 30mm diameters, with a 3mm shaft diameter. 120grit.
PROXXON Diamond Cutting Disc
For cutting marble, brick, plaster and many other materials in the sanitary and electrical fields. Only 0.6mm kerf, 20mm diameter, with a 2.35mm diameter arbor.
PROXXON Wire Wheel Brushes
22mm diameter wire brushes mounted on an arbor with 2.35mm shaft diameter. Arbor plus 5 Steel brushes.
PROXXON 38mm Cutting Discs & Arbor
Reinforced aluminium 38mm diameter discs for cutting metals, wood and plastics. Available as a pack of 5 discs, including an arbor with a 2.35mm diameter shank.
PROXXON Spring Steel Cutting Blades
Cutting blades made of spring steel, only 0.1mm thick. For plastic, wood and non-ferrous metals. Three blades included in the pack, one of each: 16, 19 and 22mm diameter, includes arbor with 2.35mm shank.
  • 5 x 120 grit and 5 x 150 grit discs
  • Arbor, 3mm shaft
  • PROXXON Flap Sanding Wheel
  • For general shaping and smoothing
  • 30mm diameter, 120 grit
  • PROXXON Diamond Cutting Disc
  • Cuts marble, brick, plaster
  • Diamond coated edge
  • 20mm diameter
  • PROXXON Wire Wheel Brushes
  • 22mm diameter wire brushes
  • 5x Steel wire brushes
  • PROXXON 38mm Cutting Discs & Arbor
  • 5 pack of 38mm reinforced aluminium cutting discs
  • Arbor with a 2.35mm diameter shank
  • For cutting metals, wood and plastics
  • PROXXON Spring Steel Cutting Blades
  • Spring steel cutting blades
  • Pack of 3
  • 1 each 16, 19 & 22mm diameter
  • For cutting plastic, wood and non-ferrous metal
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
