PROXXON FLEX-DOT Screwdriver - 1/4" Hex Autolock Chuck
- Autolock bit chuck provides a secure grip on 1/4" hex bits
- Bits lock automatically on insertion
- Fatigue-proof and comfortable FLEX-DOT handle
- Blade length 110mm, overall length 220mm
A screwdriver designed to utilise 1/4"(6.35mm) hex standard screwdriver bits. The shaft has an Autolock bit chuck which provides a secure grip on 1/4" hex bits. The bits lock on insertion, to release, you simply push the sleeve forwards. The rounded 2-component handle with flexible "FLEX-DOT" nubs provides a fatigue-proof and comfortable grip, especially for continuous use. The handle is also oil and acid resistant. Blade length 110mm, overall 220mm.
EAN Barcode | 4006274222823 |
Model | flex-dot |
- Standard Delivery* - £1.99
