PROXXON IGS/A Cordless Industrial Straight Grinder - 10.8V (2.6Ah)
- Built to last; die-cast aluminium gear head
- Soft grip insert offers comfort and improves control
- Versatile, 6.5mm capacity chuck for variety of accessories
- Continuously variable speed control (1,500 - 4,200 rpm)
- Compact design and lightweight, easy to handle
- Supplied with a 10.8V (2.6Ah) battery, rapid battery charger, 50mm diameter wire brush and storage case
The Proxxon IGS/A industrial straight grinder draws power from a 10.8V (2.6Ah) L-ion battery giving you performance easily comparable to its mains-powered cousin. Built to last; the gear head is die-cast aluminium and the main body housing is glass-fibre reinforced POLYAMIDE. The soft grip insert offers comfort and improves control.
The IGS/A features a continuously variable speed control (1,500 - 4,200 rpm) with a special balanced DC motor giving plenty of power at low speeds. The specifications and features mean this tool can be used for a myriad of tasks such as brushing, grinding, frosting, deburring, paint stripping and more. The compact design and lightweight (970g) make the IGS/A very easy to handle compared to standard size grinders. It comes with an industrial keyed drill chuck with a capacity from 0.5 to 6.5mm.
The IGS/A is supplied with a 10.8V (2.6Ah) L-ion battery Li/A2, a rapid battery charger LG/A2 and a 50mm diameter wire brush. All contained in a tough, high-grade polypropylene storage case.
Length 290mm, weight 970g (incl. battery).
Batteries Included | 1 |
Battery Capacity | 2.6 Ah |
Battery Type | Li-ion |
Battery Voltage | 10.8 V |
Chuck Capacity | 0.5 mm to 6.5 mm |
Chuck Type | keyed |
Corded or Cordless | Cordless |
EAN Barcode | 4006274298507 |
Model | IGS/A |
Nett Weight | 970g (with battery fitted) |
Rating | Trade/Professional |
RPM | 1,500 - 4,200 rpm |
- Standard Delivery* - Free
