PROXXON IGS/A Industrial Straight Grinder (Body Only)
109507
From £110.98 £92.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 20th May
  • Built to last; die-cast aluminium gear head
  • Soft grip insert offers comfort and improves control
  • Versatile, 6.5mm capacity chuck for variety of accessories
  • Continuously variable speed control (1,500 - 4,200 rpm)
  • Compact design and lightweight, easy to handle
  • Body only tool, supplied in cardboard box with with 50mm wire brush
The Proxxon IGS/A industrial straight grinder when fitted with a battery offers you performance easily comparable to its mains-powered cousin. Built to last; the gear head is die-cast aluminium and the main body housing is glass-fibre reinforced POLYAMIDE. The soft grip insert offers comfort and improves control.
The IGS/A features a continuously variable speed control (1,500 - 4,200 rpm) with a special balanced DC motor giving plenty of power at low speeds. The specifications and features mean this tool can be used for a myriad of tasks such as brushing, grinding, frosting, deburring, paint stripping and more. The compact design and lightweight (970g) make the IGS/A very easy to handle compared to standard size grinders. It comes with an industrial keyed drill chuck with a capacity from 0.5 to 6.5mm.
Note this is a body only tool supplied with a 50mm wire brush in a cardboard box without battery or charger.
Length 290mm, weight 970g (with battery fitted).
