Package deal comprises the PROXXON KS 230 Saw and the PROXXON HSS Fine Blade for KS230E.
PROXXON KS 230 Saw
A small precise mains driven modelling saw with an 8mm depth of cut using the standard 58mm diameter blade. It has a fully machined aluminium table top some 160 x 160mm mounted on a sturdy ABS base, and comes with a mitre fence and rip fence. There are 2 blades available for different materials, the 300108 alternating set for wood and plastics and the 300109 for fine cuts. There is a 34mm diameter dust extraction port at the rear of the machine.
50mm diameter Spring Steel Saw Blade(10mm bore). Designed with fine teeth for precision cutting.
