PROXXON KT 150 Aluminium Die-Cast Compound Table
474334
From £186.38 £155.32
7 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Thursday 10th Jul
  • For routing, milling, slotting of steel, non-ferrous metal, plastic and wood
  • Dovetail fittings/gib strips adjustable to eliminate play
  • Feed adjustments by means of 2 hand wheels
  • Adjustable, graduated dials (1 grad = 0.05mm)
  • Machined table with 3 T-slots
  • Max. travel 150 x 150mm
  • Overall height 75mm. Weight 4.9 kg
  1. PROXXON KT 150 Aluminium Die-Cast Compound Table
Total:
£654.22 £545.18
With precision milled dovetail slides, this is also suitable for metal work. For routing, milling, slotting of steel, non-ferrous metal, plastic and wood. Each slide provided with locking screws. Dovetail fittings/gib strips adjustable to eliminate play. Feed adjustments by means of 2 hand wheels with adjustable, graduated dials (one graduation = 0.05mm, 1 revolution = 2mm). Machined table, 3 T-slots for fastening machine vices and clamping kits. Fence supplied with pre-drilled positioning holes, including 45°, fastenings screws and clamp used for routing. Table 200 x 200mm. Max. travel 150 x 150mm. Overall height 75mm. Weight 4.9 kg.
4.00 7
