Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Proxxon LHW Long Neck Angle Grinder c/w Arbortech Mini Blades
Code: 718300
  • Perfect for texturing your woodturning
  • For steel, non-ferrous metals, glass, ceramics, wood and plastic
  • Supplied with grinding disc, fan sander and cutting disc in neat plastic case
  • Quiet and long lasting DC motor
  • Supplied with 2 Arbortech mini blades
  • Show More
£107.99 (£89.99 Ex. VAT)
In stock - get it Saturday 6th Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (3-5 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Proxxon LHW Long Neck Angle Grinder c/w Arbortech Mini Blades
  • Proxxon TCT Rasp Disc
  • Hermes Abrasive Disc -  50mm x 60 Grit (Pkt 10)
  • Saburr Tooth Round Face Carbide Disc 2" (50mm)ø Fine
Total: £203.13
Description
In Detail
For working with steel, non-ferrous metals, glass, ceramics, wood and plastic. For cutting, rough-machining, grinding, precision polishing, fine polishing and texturing wood. It features a specially balanced, 100W powerful, quiet and long lasting DC motor. Supplied with a grinding disc (60 grit), fan sander (100 grit) and cutting disc in neat plastic case. This grinder will accept the blades for the Arbortech mini carver which further increases its potential for texturing or shaping. Supplied with a pack of 2 Arbortech mini blades. Remember, it is important to keep your blades sharp and to be used with smaller projects. N.B. Machine must be used in accordance with instructions as prolonged hard use will significantly reduce motor life.
Specification
Specification
Bore Size 10 mm
Corded or Cordless Corded
Disc Diameter 50 mm
Model LHW
Motor Power 100 W
Nett Weight 0.55 kg
Rating Trade
Sound Pressure Level [Uncertainty K] 78 dB(A) [3.0 dB]
Vibration Grinding [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Voltage 230 V
Disc Speed 13,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
