Earn extra with DOUBLE Points on all purchases!
PROXXON MICROMOT MB 200 Drill Stand
- Head can be tilted through 90° allowing for diagonal drilling
- Part of PROXXON's 20mm Collar System
- Throat capacity of 140mm
Perfectly precise with PROXXON - The 20mm Collar System
Available on selected PROXXON tools. The 20mm collar system enables you to have increased versatility and accuracy with your PROXXON tool. Simply clamp the collar of your tool to the variety of devices PROXXON has available and you'll be able to take on a range of tasks, including routing, engraving and drilling whilst getting the accuracy you need as your tool is held steady.
The MICROMOT MB 200 drill stand is made from diecast aluminium. It has a 20mm collar, which when used in conjunction with other 20mm collar PROXXON tools, it can be used for bevelled drilling and versatile milling operations. The head can be tilted through 90° allowing for diagonal drilling. The solid, hard chromium plated steel column measures 280 x 20mm and gives a throat capacity of 140mm. The table measures 220 x 120mm and has all holes pre-drilled and tapped to accept the KT 70 compound table. Weight 2.2kg.
EAN Barcode | 4006274286009 |
- Standard Delivery* - Free
