PROXXON Router Base OFV
505907
From £32.28 £26.90
  4. Half Star
7 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Saturday 25th Jan
  • Turns a drill into a miniature router
  • Part of PROXXON's 20mm collar system
  • Made of die-cast aluminium
  • Fence provided with a throat depth of 150mm
  • Interchangeable circle guide
  • Can be used to drill a round section workpiece
  • Adjustable depth stop with pre-selected travel stroke
  1. PROXXON Router Base OFV
Total:
£237.32 £197.77
Perfectly precise with PROXXON
- The 20mm Collar System
Available on selected PROXXON tools. The 20mm collar system enables you to have increased versatility and accuracy with your PROXXON tool. Simply clamp the collar of your tool to the variety of devices PROXXON has available and you'll be able to take on a range of tasks, including routing, engraving and drilling whilst getting the accuracy you need as your tool is held steady.
The addition of a PROXXON OFV will turn a mini-drill or grinder into a very useful miniature router which may be well suited to toy making or dolls house projects. The 20mm collar allows you to easily connect to PROXXON's other 20mm collar tools. The base is made from die-cast aluminium with a milled working surface and a fence is also included with a maximum throat depth of 150mm. In addition, there is an interchangeable circle guide. The router base has an adjustable bench stop with a pre-selectable travel stroke. It can also be used as a drilling guide for round parts as a triangular prism is provided in the work base.
3.30 7
