This is a precision jigsaw for cutting smaller and more intricate work. The main housing is die-cast aluminium for longevity. The base tilts up to 45° for mitre/angled cuts. The stroke speed is variable between 2,000 and 4,500 strokes per minute, with full wave electronic speed control. An ideal tool for cutting very tight curves in wood, PC cards (up to 5mm thick) and non-ferrous metals (up to 3mm thick). It is supplied in tough moulded case with 4 Super-Cut blades for wood, plastic and metal. Maximum power consumption 100W, 230V. Stable head of die-cast aluminium; main housing made of fibreglass reinforced polyamide. Length 230mm. Weight 700g. Insulated to class 2.
