Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Everything you want from a stationary belt sander in a small precise form with extra versatility. It is ideal for fine sanding work and the most minute corrections on soft and hard woods, non-ferrous metals, steel, plastics (perspex and PC cards) and cork.
Sands long edges, end sections, radii, mitres, and, by turning the workpiece over it also accurate works flat surfaces at right angles. The sturdy plane-milled die-cast aluminium table is 210 x 145mm, offering plenty of support for small work pieces. The table has a mitre slot for the mitre fence allowing you to sand at exact angles. A scale with and a locking knob enables you to angle the belt from 0° to 90°, allowing you to use the belt vertically or flat and anywhere in between. When used flat the mitre fence becomes a stop.
The TB50 is powered by a balanced DC-motor with a no-volt release switch. The belts are 50 x 533mm and run at 400m/min for fast and highly effective sanding. Belt changes are easy thanks to the spring loaded rollers, which also feature fine adjustment for belt tracking. The well designed dust hood is highly effective when connected to a suitable vacuum for extraction.
The compact design means you can stow the TB50 easily after its work is done.
Replacement belts available in sizes;
100g (SKU 109970)
180g (SKU 109971)
240g (SKU 109972)
PROXXON Micromot: 2 year warranty for private use, 1 year warranty for commercial use
