Rider No. 92 Shoulder Plane
- Highly accurate, shoulder plane, 19 mm wide blade
- Precision machined, precision ground for accurate results
- Sole is flat and the sides are square to the sole
- Movable front section for coarse or fine work
- Converts into a chisel plane, for cleaning stopped rebates
- Full width blade, micro adjustable depth of cut
The Rider No. 92 shoulder Plane; cast from fine grey iron, is precision machined, precision ground and polished to ensure accurate results. A finger recess on both sides and a well-rounded upper section combine to ensure a comfortable grip. The sole is flat and the sides are square to the sole. The 19 mm (3/4") full width blade is micro adjustable for precise control of the depth of cut. The blade is a fraction of a smidgen wider than the body making it easier to work into the corner of a shoulder.
The upper section is movable, forwards or backwards varying the width of the mouth for fine or coarse work. Removing the upper section completely, converts the plane into a chisel plane, useful when working on a frame, where the stile and rail rebates meet. A small set screw inside the front section ensures you retain the original mouth setting when reassembling the plane.
Rider planes only require the bare minimum of initial preparation. The blade is oil quenched, high carbon spring steel, hardened and tempered to HRC 63, and only requires honing before use. We are confident that Rider planes represent a good standard in traditional, quality plane manufacture and great value.
| EAN Barcode | 5052511122356 |
| Model | No.92 |
| Nett Weight | 516 g (1lb 2oz) |
| Plane Blade Type | O1 |
| Plane Blade Width | 19 mm (3/4") |
| Plane Sole Length | 155 mm |
| Plane Type | Shoulder |
- Standard Delivery* - Free
