RJH Antelope Bandfacer Dust Extraction Mounted 1ph
- Mounted on floor stand with built-in dust extraction unit
- Dust tray collector for easier and cleaner waste handling
- Filter service indicator light
- Full guarding incl adjustable front belt guard
- Knee operated stop bar
- Quick action calibrated tilting work table
- Mitre guide included
- 750W 1ph 230V motor
- Supplied with 150 x 1090mm aluminium oxide abrasive belt
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.18 £10.98
Axminster Professional Cyclone Extractor Filter Waste Sacks (Pkt 5)From £13.98 £11.65
The RJH Antelope Bandfacer (1ph 230V) meets strict performance and safety criteria, and is ideally suited for use in schools and colleges. Particular attention has been given to safety, ergonomic design and user-friendly features.
The machine is suitable for working on wood, acrylic or metal. The floor stand houses the integral dust extraction unit with a polyester needle-felt filter. Efficient extraction results in a clean working environment.
The front of the machine features a quick-action adjustable work table with a mitre guide for producing accurate angles.The table can be positioned between 90° and 135° in relation to the face of the abrasive belt.
The Antelope complies with UK COSHH regulations, the European Machinery Directive and with the BS 4163:2014 “Health and Safety for Design and Technology in schools and similar establishments” regulations.
All RJH education machines carry a 2 year warranty. Supplied with 150 x 1090mm aluminium oxide abrasive belt.
Abrasive Belt Size | 150 mm x 1,090 mm |
Belt Speed | 390 m/min |
EAN Barcode | 5052511120871 |
Model | AN150V1COB |
Nett Weight | 135 kg |
Overall L x W x H | 660 mm x 715 mm x 1,305 mm |
Power | 750 W |
Rating | Trade/Professional |
Table Size | 278 mm x 226 mm |
Voltage | 230 V |
This product is classified as an Enquiry product. Enquiry products require contact with our friendly Business Services team prior to purchase to understand your requirements. Typically these products have many customisation options or require product training.
Enquiry products are usually readily available and often despatched directly from the manufacturer using the best delivery service available. Despatch times can vary between manufacturers and delays may occur should stock become unavailable. Please contact customer services for more information.
- Standard 3-5 Day UK* - free
