Robust Mini Tool Rests
- Hardened steel bar on top edge will not dent or nick
- Robust; solid steel construction
- For all lathes with 16mm (5/8") tool post diameter
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Robust Mini tool rests have 16mm (5/8") tool posts offering all the benefits of larger Robust rests to owners of smaller lathes such as the Axminster Craft AC305WL and AC240WL. These rests feature a hardened steel rod as the tool bearing surface that provides smooth tool transition and will never ding, nick or need filing. Your tools will glide effortlessly across the rod even after years of turning. Your hand fits comfortably in the radius of the rest, whether you use an overhand or underhand grip. You can get the rest close to the action for maximum tool support whether below or above centre height.
EAN Barcode | 5052511123988 |
Tool Post Diameter | 16 mm (5/8") |
Tool Rest Length | 100 mm |
