- large delivery. Contact us for a personalised quote
IMPORTANT: Please contact Axminster Tools to arrange a more detailed explanation of the Robust Scout Woodturning Lathe and the options available to suit your individual needs. Please call 03332 406 406 to speak with our specialist sales team to arrange the consultation or fill in the enquiry form further down the page. This machine is delivered by our own Axminster transport team.
When it comes to the comparing bench top lathes, the Robust Scout must come top of the list. The design and build quality are second to none. Robust Scout is one solid, well built benchtop lathe.
To begin with you get stainless steel bed ways on a rigid fabricated steel bed. A 1.1kw motor and inverter offer dial controlled variable speed (50-3,000rpm), with digital readout and reverse. The single pulley design means plenty of torque, without fiddly belt changes. The spindle lock disconnects the controls preventing accidental start-up. Another great safety feature is the stop bar, running the full length of the lathe bed. With both hands holding a tool, a quick nudge with your hip stops the lathe. The headstock has a 24-hole index with each stop lockable with a pin. The tailstock quill has 75mm of smooth travel for boring.
Overall the Scout is a lot of lathe. If proof were needed of the quality, the 7-year warranty proves the faith that Robust have in their products.
Optional accessories include a bed extension, increasing the standard 660mm between centres to 1,065mm, and the unique universal stand, which is adjustable in height and can even be configured to allow you to turn whilst seated.
N.B. As lathes will be made to order, a 15% non-refundable deposit will be required. Additional information will be given by our specialist sales advisor upon enquiry.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
