If you have made some pens using our acrylic and polyester blanks, you will be interested to learn that we can now supply a range of polyester project kit blanks of larger dimensions than the pen blanks. The size of these blanks is 114 x 35mm which gives you more choice in the way you can use the material. For instance, you could use the material for turning larger projects such as bottle stoppers, light pulls, pendants and knobs or by cutting the blank lengthwise into four pieces, you will have four pen blanks at your disposal. We recommend the use of wet and dry abrasives for finishing this product followed by burnishing cream. Let your imagination run wild!
