Mirka Sanding Blocks with Extraction
953287
953287
In Stock
- get it Friday 19th Aprget it Monday 22nd Apr, order within and choose Premium delivery. Delivery info
- Mirka hand sanding blocks with dust extraction port
- Makes dust free hand sanding a reality
- Use with Abranet abrasive for perfect results
- 70 x 125mm pad size
- Very efficient, clean sanding when connected to a suitable extractor
Show more
Show less
Dust free sanding is now a reality when using Abranet® abrasives combined with dust extraction. These hand sanding blocks with hook and loop attachment pads from Mirka are available in two sizes, they are light in weight and very comfortable to hold. A 20mm x 4 metre long dust extraction hose is available which has a universal fitting to suit most sizes of vacuum extractor. Ideally suited for many applications and particularly useful for rubbing down fillers when decorating. These blocks allow for a cleaner working environment and minimum clean-up. 70 x 125 mm pad size
- Standard UK (1-2 days) - £5
- Premium UK (next day) - from £10
#AxminsterTools
