Scan 4 Dial Combination Key Safe
The Scan Keysafe is the ideal safe storage of house, car and padlock keys. Its 4-digit combination allows for 10,000 different codes for added convenience and improved security. A plastic shutter door protects the combination dials from the elements ensuring no dirt or grit gets into the mechanism. Can be wall mounted using the supplied fixings (check substrate for correct fixings) It can be mounted either inside or outside. Suitable for the home, office, workshop, or anywhere where keys are required in an emergency. Specifications: Width: 90mm. Height: 119mm.Depth: 49mm. Security Rating: 6.
EAN Barcode | 5023969007700 |
- Standard Delivery* - £1.99
*UK Mainland only. Order before 3pm for Next Day Delivery. Additional charges may apply for remote or offshore areas.
