A combination machine offers different functions in one compact and multifunctional unit. The SCM C30G 4-Function combination machine with all Minimax’s quality is an ideal choice for an ambitious home woodworker or light trade workshop. The C30G comes as standard with: ease-of-use, flexibility, precision, and safety. The C30G has three independent motors each dedicated to one of the functions and controlled separately. The machine tables are cast iron and mounted on a steel fabricated base unit. The fences are extruded anodised aluminium and are all fully adjustable. The C30G comes with a wheel kit. Even a small workshop where space is at a premium can accommodate this 4-function machine.
The saw offers a maximum cutting height of 90mm and tilts up to 45°. For crosscutting, the sliding table and aluminium fence provide a very accurate means for making square and angled cuts. The fence comes with a repeat stop.
The spindle moulder has a 30mm spindle with two speeds. The spindle has a capacity of 75mm in length. The recess in the table will accept tooling up to 145mm in diameter.
The planer has a 300mm wide by 1,200mm long table. The planer is fitted with a TERSA 3-knife block for a clean cut and easy changing and setting.
Thicknessing is a matter of raising the tables and relocating the dust hood. Timber up to 300mm x 200mm can be accurately dimensioned. The timber is fed by feed rollers at a fixed speed of 6 metres per minute.
An exceptionally useful machine if you have limited space.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
