Tite-Fix Screw-Tite Yellow Pozidrive Countersunk Screws
From £2.48 £2.07 was £2.48 £2.07 Save £0.00 £0.00
  5. Half Star
3 Reviews
  • Tri-lock TS Threadform for an immediate start
  • Tri-lock shank means there is 25% less insertion torque
  • High-quality pozi, multipurpose screw
  • For use in a large range materials without the need to pilot hole in most cases
  • Double countersunk head ensures a clean, flush finish
Tite-Fix Screw-Tite pozi screws are the fixing for you if you want a guaranteed, high-quality finish. These multipurpose, advanced screws have a unique Tri-Lock TS Threadform which joins together the benefits of a single thread and twin thread in one screw. You will get a balanced, immediate start with a fast insertion leaving you with a firm fix. The tri-lock shank ensures there is 25% less insertion torque, so your timber will not receive any damage. Screw-Tite screws can be driven into a large range of materials including hardwood, softwood, masonry, sheet steel, plastic and more without the need to drill pilot holes in most cases. The double-countersunk head means you will achieve a clean, flush finish every time. These screws have a PZ recess.
Please note, a pilot hole is needed when using masonry.
4.70 3
